Struggling To Get A Start
#16
Posted 12 April 2019 - 02:04 PM
#17
Posted 12 April 2019 - 05:41 PM
#18
Posted 12 April 2019 - 05:49 PM
1993 was well into the SPi era, wasn't it?
Only coopers were spi at the point my car was built
#19
Posted 12 April 2019 - 05:55 PM
#20
Posted 12 April 2019 - 07:31 PM
This one is an Italian Job, so probably using up the old carb engines in a small production run that would be easy to sell.
#21
Posted 12 April 2019 - 08:08 PM
I have 2 engines, one from a 1993 IJ, the other a sprite, these engines used the HIF38 carb, the only difference is the cam iirc
#22
Posted 16 April 2019 - 07:55 AM
This one is an Italian Job, so probably using up the old carb engines in a small production run that would be easy to sell.1993 was well into the SPi era, wasn't it?
And I think the cam differences are only down to the oil pump drive - star or slot.
#23
Posted 22 April 2019 - 02:16 PM
Just thought I'd add another update. Got the engine running up to operating temperature and checked the mixture, using a colourtune. Needed adjustment to get nice blue colour after initial orange at idle. Then checked strobe timing. Found it was about 20 BTDC, so advanced it to 5 or 6 BTDC. Engine sounded much better, BUT now it will not idle. Engine speed comes down to 1000, then just dies, no matter what throttle input you give it. Also seeing a tendancy to spit back through the carb intake (air cleaner not currently fitted). About to repeat mixture check and timing check, but any other thoughts guys?
