Black Primer
3 replies to this topic
#1 stumpy75
stumpy75
  • 291 posts
Posted 11 March 2019 - 12:08 AM
Found on heritage panels ive read elswhere that its the best primer you can get should be left on and flatted prior to painting is that correct and can you buy this primer
#2 Dusky
Dusky
  • 5,322 posts
Posted 11 March 2019 - 07:11 AM
I would not. The electro primer that's put on isnt the best. It's also always best to use a full paint system that's known to work together.
#3 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 11 March 2019 - 09:51 AM
I've never had issues with leaving it on however you sometimes find with heritage panels that there is rust trails beneath the primer.
If there is any doubt, just remove it.
If you do leave it on, then dry flat it to remove imperfections and cover any bare areas with primer after.
I tend to sand with a random orbital sander with 400grit and then prime over the top of the lot.
Ben
Edited by Ben_O, 11 March 2019 - 09:53 AM.
#4 stumpy75
stumpy75
  • 291 posts
Posted 11 March 2019 - 10:26 AM
So much misinformation out there regards this stuff thanks guys
