Engine Steady Question
2 replies to this topic
#1 PauloPereira
PauloPereira
    Just On Tickover
  • 9 posts
Posted 12 March 2019 - 02:41 PM
Hello. Ran into a snag. I'm in the process of replacing the upper engine steady bushings on my MPI. What should be a easy job, has turned into a nightmare. Everything came out ok, replaced the bushings, and putting it all together is a pain. I'm having issues with installing the bolt that attaches the steady to the engine block. I coud swear that the longer bolt goes into the block and the shorter on the other side. Is that correct? I can get the bolt started into the block without any issue, but then it quickly becomes almost impossible to tighten any further. Of course I don't want crank on it to the point of stripping things. I've checked the workshop manual and it doesn't show the lengths. Any ideas? thx
#2 nicklouse
  • 19,067 posts
Posted 12 March 2019 - 02:55 PM
http://www.minispare...A1817.aspx|Back to
#3 PauloPereira
PauloPereira
    Just On Tickover
  • 9 posts
Posted 12 March 2019 - 05:55 PM
Damn, that means I've got a problem. Thx tho :)
