Only Sparking On 2&4?
Posted 13 March 2019 - 08:50 PM
Posted 13 March 2019 - 09:05 PM
Try temporarily swapping the leads over (e.g 1 with 2, 3 with 4), see if the spark "moves" with the leads. This should help to narrow down the cause.
Posted 13 March 2019 - 09:29 PM
Am I right in thinking either the points work or they don't, not just on position 2 and 4.
Posted 13 March 2019 - 09:32 PM
So if you swap leads 1 & 2 around (on the spark plug or the dizzy end, not both), the spark is still on 2? Was it running okay with the new cap, condenser etc. before the rebuild?
Edited by smurfomatic, 13 March 2019 - 09:33 PM.
Posted 13 March 2019 - 09:43 PM
sounds like the cap is not located properly??
1-3-4-2
4-2 side ok and 1-3 not???
only a guess
Edited by Avtovaz, 13 March 2019 - 09:44 PM.
Posted 13 March 2019 - 11:49 PM
Posted 14 March 2019 - 01:06 AM
Spin the engine over and check the points are opening on all the lobes, have a look for play on the shaft while your there. How are you checking for spark ? lead to the block or a plug earthed on the head? Its unusual to not spark on 2 when the other 2 are ok. Visually check everything again it should be something obvious.
Posted 14 March 2019 - 11:16 AM
Make sure all the leads are pushed in to the dizzy cap and the contact part is not too small
Its worth checking the rotor arm contacts in the cap may not be central
Did you gap the plugs at 0.025 " and make sure the cap end of each plug is tight on the threads
Engine and battery earth good ?
King lead contact in dizzy cap OK ?
Have you got a lucas type quality condensor ? other types are pretty useless with about 1/2 the wire inside
Posted 14 March 2019 - 09:01 PM
