Mpi Transplant - Misfire Under Load
#16
Posted 13 April 2019 - 09:13 PM
When the crank sensor went on my old Si, before it failed totally it caused an intermittent miss (the failure was in the wires from the connector to the sensor)
#17
Posted 15 April 2019 - 01:10 AM
If it is running "fine" while cold and starts acting up once it is warmed up, it could be the O2 sensor is sending bad data. Unplug the sensor and see if it runs better without it. There is nothing to lose.
Edited by xrocketengineer, 15 April 2019 - 01:11 AM.
#18
Posted 15 April 2019 - 11:09 AM
If the new crank sensor doesn't do the trick, then I shall give this a go. I had ruled it out as on the diagnostics it wasn't flagged or showing unusual values.
#19
Posted 16 April 2019 - 04:42 PM
New crank sensor fitted. The old one did have a lot of smeg on the pickup, but same again. drives great til 75deg, then the miss (mainly on part throttle) comes back. tried unplugging the Lambda, no difference (and it does look quite new).
I can't help but think that the cold starting quirk is linked in that from cold it won't catch on the 1st or 2nd turn of the key.
#20
Posted 16 April 2019 - 05:18 PM
If you ignore the mystique surrounding the MEMS system, and treat it like any other car; the coil pack would be a strong shout.
But don't shout at me if it's not.
#21
Posted 16 April 2019 - 05:29 PM
Bit of a guessing game, but it still could quite easily be Coil Pack.
At this point, I second the motion.....
#22
Posted 16 April 2019 - 07:43 PM
#23
Posted 16 April 2019 - 07:51 PM
#24
Posted 16 April 2019 - 08:21 PM
How are you measuring water temp?
On a smiths gauge hooked into the original dial wiring. But we did check it’s readings against the values on the diagnostic kit and it was pretty accurate
#25
Posted 17 April 2019 - 01:03 AM
Since the issue seems to be associated with temperature, is there an air temp sensor like in the SPI?
#26
Posted 17 April 2019 - 11:06 AM
On the MPI's they have air temp, MAP, TPS, Cam Position, crank position, Lambda, water temp and oil temp (but apparently the ECU doesn't use oil temp).
When we had it running on the diagnostics (all that follows are the opinions of my mate that has the kit and used it on many minis over the years), air temp looked fine, water temp looked fine (but has since been replaced as I thought I had broken it as the connector rotated), the Lambda figure looked in range (and looking recently it does look to be pretty new), MAP figures looked happy, TPS gave a full range of values.
#27
Posted 17 April 2019 - 12:06 PM
My question about the air temp sensor is if the reading is fixed. Like if it is reading relatively warm (above ambient) with the engine cold possibly causing hard cold starting but and relatively warm when the engine is hot causing the other condition. If that does not pan out, then a check of the fuel pressure would be prudent.
#28
Posted 06 May 2019 - 12:49 PM
