Rear Bins
Posted 17 March 2019 - 08:31 PM
Ta
Posted 17 March 2019 - 10:33 PM
they are also part of the rear seat base.
Posted 18 March 2019 - 06:45 AM
I should have said the rear seats have been removed.
Posted 18 March 2019 - 10:45 AM
With the seat pan removed and an alternative seat belt mounting point installed then you should be fine. As they are the bins are flimsy, but as a precaution adding in some extra welds either spot or seam weld would do no harm.
Posted 18 March 2019 - 04:55 PM
So if I remove the seat base and rear bins but then add in extra welds it'll be OK.
I'm not building a rally car or race car just weightsaving.
Posted 18 March 2019 - 08:31 PM
You have a cage which depending on the type will help with strength and adding extra welds will help. I have more welds on my car than standard plus they are considerably larger ie 1/4" plug welds whereas most you find on a mini are smaller.
Is the harness bar welded in place with reinforcing plates on the arches??
