Mot - Brake Servo?! (1991 J Reg Mini)
18 replies to this topic
#1 minimotor_JD
minimotor_JD
  • 334 posts
Posted 19 March 2019 - 01:50 PM
Hi All,
For the first time I had my car not pass an MOT due to it requiring a brake servo (i've been told), I've had the obp pedal box installed since 2012 and not had any issues regarding MOT's in the pass, the MOT'er is saying that the car is failing by not locking the front wheels on this particular part of the test.
http://www.obpltd.co...me=classic mini)
Its a 1991 Mini but registered in 1992 April
Any suggestions? Maybe I should take it to a different MOT place!
#2 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,714 posts
  • Name: Chris
  • Local Club: None
Posted 19 March 2019 - 02:00 PM
Are you able to adjust the front brakes at all?
#3 nicklouse
  • 17,935 posts
Posted 19 March 2019 - 02:07 PM
interesting. as a servo will not increase the braking power.
sounds like the tester needs to apply more power.
if it needs to lock the front brakes then you need to change the MC piston size.
#4 minimotor_JD
minimotor_JD
  • 334 posts
Posted 19 March 2019 - 02:14 PM
I can adjust the brake bias as its split front to rear
I was thinking that too - Likely hasnt come across this type of setup before as its a new MOT place I'm using - More force required, will feed that back.
Interesting they're saying they're happy with the brake performance!?? - Odd
#5 nicklouse
  • 17,935 posts
Posted 19 March 2019 - 03:04 PM
I would wind more bias to the front for the test and remember so you can readjust for road use later.
#6 imack
imack
  • 1,868 posts
Posted 19 March 2019 - 09:17 PM
What is the actual reason for rejection on the failure form?
Front brakes not locking out isn't in itself a reason for rejection so long as the overall efficiency is over 50%.
Having said that, if you can't lock the front brakes you've got a problem or weak legs!
Or is he trying to fail it because he doesn't like the fact that the servo is missing?
Just had a very quick look at the manual and can't see that servo missing is a rfr.
#7 Itsaminithing
Itsaminithing
  • 851 posts
  • Local Club: Not One Worth Mentioning
Posted 19 March 2019 - 09:56 PM
Section Braking Systems and Additional Braking Devices
From the Jan 2012 MOT Inspection Manual (but it goes back before that edition)
Section 3.6 Braking Systems & Additional Braking Devices
Reason for Rejection
1. A servo:        a. missing when fitted as standard
Edited by Itsaminithing, 19 March 2019 - 09:58 PM.
#8 imack
imack
  • 1,868 posts
Posted 19 March 2019 - 10:17 PM
Manual changed in may 2018, I know it used to be in there but I can't quickly see a reason for rejection in the current manual.
#9 cal844
cal844
  • 9,486 posts
  • Local Club: TFMOC
Posted 19 March 2019 - 10:19 PM
If it's missing it can't be tested, simple! You don't need lights or indicators, nor a handbrake....
#10 imack
imack
  • 1,868 posts
Posted 19 March 2019 - 10:29 PM
Yeah, you can get away with not testing certain items if they're not fitted, but not everything. I know about the lights but it has to meet a certain criteria to not require lights from memory.
Handbrake? Thats a new one on me, I'll have to look it up....
#11 Itsaminithing
Itsaminithing
  • 851 posts
Posted 19 March 2019 - 11:07 PM
I see what you mean....
Section 1.1.10 Brake servo units & master cylinder (hydraulic systems)
a. brake servo     i. defective or ineffective -Major category
                            ii. inoperative - dangerous Category
& absolutely nothing at all about a servo having been removed!!!!!
(despite the fact that it's not mentioned in the section on what changes there were to the previous editions).
If only we knew a MOT inspector we could ask about this ;-)
#12 Dan the Van
Dan the Van
  • 55 posts
Posted 20 March 2019 - 07:34 AM
Is it a 998?.If so servo was optional not standard.(never fitted to my 89 Mayfair).
#13 imack
imack
  • 1,868 posts
Posted 20 March 2019 - 08:18 AM
I don't know what year they were fitted as standard
#14 cal844
cal844
  • 9,486 posts
  • Local Club: TFMOC
Posted 20 March 2019 - 09:50 AM
My 89 Mayfair has one, my 80 estate doesn't
#15 Cooperman
  • 23,036 posts
Posted 20 March 2019 - 10:50 AM
I spoke with my MoT tester and he said that whether or not a servo is fitted is immaterial. What the braking system MUST do is to meet the braking force requirements as shown on their rollers.
But that is just one tester's interpretation.
