I want to re-fit my Nardi steering wheel back into Pootle now I've completed the MPI transplant. I've got a boss off eBay for a MGF, complete with a ring with 2 tabs on it. I've removed the steering wheel and the clock spring unravelled (not sure if that's what its supposed to do or if its bust), but as to how I reattach it all I'm not getting (and sadly the seller didn't supply any instructions).
Is There A How-To For Fitting A Aftermarket Steering Wheel On A Mpi?
Posted 20 March 2019 - 06:22 PM
Posted 20 March 2019 - 09:09 PM
this is what notes u have
tools - t27 for airbag bolts
19mm socket steering wheel
wire disconnects from air bag it self
The cover and airbag is one part. It is secured to the steering wheel by two torx screws from the rear. These need to be undone and then the airbag module can be removed and unplugged.
As above, remove the ignition key, disconnect the battery ( both terminals ) and leave for at least 10 minutes for the SRS backup system to discharge
rotary coupler / squib part number YRC100300 same as mgf ?
If the bag has been fired in the past and the srs ecu hasn't been replaced, the light will stay on. Also if any pretensioner or the airbag is duff it will come on.
Posted 20 March 2019 - 09:30 PM
whoops did not see the aftermarket bit,
check with ya insurance company first as it might make ya insurance invalid with airbag removed or messed about with... soz not much use is me lately….
Posted 20 March 2019 - 10:47 PM
Looking at clock springs on eBay, it seems mine is broken anyway
Posted 21 March 2019 - 09:07 AM
I've got a step by step document in pdf format, can't remember how to attach it here though
pm me your email address and I'll send it across
Posted 21 March 2019 - 10:23 AM
You can pm up to 2mb attachments via the forum.
