Oil Pressure Fluctuating
9 replies to this topic
#1 germini30
germini30
  • 746 posts
Posted 21 March 2019 - 10:22 PM
Given the mini a little blast earlier, 998cc. Its got an oil pressure gauge and always has good oil pressure but I noticed that when I got home at idle the pressure was jumping back and forth from 40-50psi. If I revved it sat at 75psi. Any reason why it was jumping back and forth at idle???
#2 cal844
cal844
  • 9,736 posts
  • Local Club: TFMOC
Posted 22 March 2019 - 10:33 AM
Because the oil is hot, it will be ok as long as the pressure doesn't drop under 20psi
When was it last serviced?
Edited by cal844, 22 March 2019 - 10:34 AM.
#3 germini30
germini30
  • 746 posts
Posted 22 March 2019 - 10:45 AM
It's just I never noticed it before but this was after a good blast. I restarted it later on and all good with no fluctuations. Maybe change oil and filter. Wasn't changed to long ago but I don't do much mileage
#4 mini13
mini13
  • 3,811 posts
Posted 22 March 2019 - 10:54 AM
has it got a ball in the relif valve as they can do this.
#5 germini30
germini30
  • 746 posts
Posted 22 March 2019 - 01:21 PM
Yes it does
#6 cal844
cal844
  • 9,736 posts
  • Local Club: TFMOC
Posted 22 March 2019 - 01:39 PM
There's the issue, change for a new thimble type oil pressure relief valve
#7 mini13
mini13
  • 3,811 posts
Posted 22 March 2019 - 02:26 PM
Yep, the balls bobble round in the oil flow.
#8 Spider
  • 15,877 posts
Posted 22 March 2019 - 05:33 PM
http://www.theminifo...huttle-vs-ball/
#9 Dusky
Dusky
  • 5,322 posts
Posted 22 March 2019 - 08:43 PM
Sensors play up as well sometimes
#10 Mathilde
Mathilde
    Starting My Mini Up
  • 1 posts
Posted 06 April 2019 - 09:46 PM
I have a similar problem, when engine is cold, starting oelpressure goes up and when ideling engine warm it does not go down, or lower
always stays there with minimal movingI  changed the oelpressure gauge and the cable, still the same the gauge is a jaeger one from Italy
different reading not psi, but checked with a smith one. it goes to 7o and stayes there,  any suggestions I try to add a photo, but how. ??
