Camshaft Shim
Best Answer Pigeonto , 22 March 2019 - 10:16 PM
Nope. Just the triangle plate
The only way to change the end float is to machine the big sprocket. Decrease endfloat by machining the extension with the little slot in it. Increase endfloat by machining the larger step that runs against the triangle plate
Go to the full post
8 replies to this topic
#1 dotmatrix
dotmatrix
  • 390 posts
Posted 22 March 2019 - 10:08 PM
isn't there normally a shim behind the large gear on the end of the camshaft to shim it to the correct endfloat? cant find it on minispares.com
Edited by dotmatrix, 22 March 2019 - 10:08 PM.
#2 Pigeonto
Pigeonto
  • 967 posts
  • Local Club: ISMOC
Posted 22 March 2019 - 10:16 PM   Best Answer
Edited by Pigeonto, 22 March 2019 - 10:23 PM.
#3 dotmatrix
dotmatrix
  • 390 posts
Posted 22 March 2019 - 10:30 PM
hm. ok. well then thats why I cant find it :) I'm sure I have seen some of my engines having a shim there though
#4 Pigeonto
Pigeonto
  • 967 posts
  • Local Club: ISMOC
Posted 22 March 2019 - 10:34 PM
Not confusing that with the shims behind the bottom, small sprocket ?
A shim between the sprocket and cam would increase the float, one between the sprocket and triangle plate would be so thin it would soon break up
#5 dotmatrix
dotmatrix
  • 390 posts
Posted 22 March 2019 - 10:39 PM
no I'm not confusing them and yes I realise you are right. but still I have seen it on at least one of my engines when taking it apart.
anyway. you answered my question. thank you :)
#6 Pigeonto
Pigeonto
  • 967 posts
  • Local Club: ISMOC
Posted 22 March 2019 - 10:43 PM
Very welcome.
Maybe some one took too much off and had to make a shim to put it right
#7 gazza82
gazza82
  • 2,902 posts
  • Local Club: TMF+
Posted 22 March 2019 - 11:18 PM
Or didn't fit a new triangular plate when it was obviously worn. My engine had too much float so I just bought a fitted a new plate ... job done. No machining, no shims.
#8 gazza82
gazza82
  • 2,902 posts
  • Local Club: TMF+
#9 nicklouse
  • 17,899 posts
Posted 22 March 2019 - 11:32 PM
a shim would not last there are is is possibly a load bearing surface. they would just fold up and disintegrate.
note some gaskets are thinner than they should be and that can cause issues.
