1989 Racing Green with Wipac H4 conversions.
Getting everything sorted for upcoming MOT...
The sidelight bulb on the nearside headlamp isn't working. Dim-dip sidelights working fine with engine running, however the small capless bulb isn't.
I've checked voltage over terminals and is over 12V. Bulb is ok as when swapped with the other side the issue stays on the nearside and doesn't follow the bulb (continuity also ok). Thought it could be a dodgy earth, however the earth is shared with main bulb which works ok (see pic).
Anything else I should be checking?
Also - I presume these need to work for the MOT as don't have sidelight on one side when engine off?
Thanks all!
IMG_2392.jpg 42.2K 1 downloads
