Loud Knocking!
Posted 24 March 2019 - 05:35 PM
The knocking sound started to appear 30 mins into driving now it appears after 5 mins of driving.
I had a similar sound with another mini I had which turned out to be big end bearings and low oil pressure. I’m worried that I have the same issue.
I don’t have an oil pressure gauge so I can only really diagnose it by listening. The knocking increases with higher revs. And the sound goes away when under load, for example letting the engine struggle at 30 mph in 4th gear. The sound is slowly getti worse, and I need some advice. How long can the car last with this issue?
Posted 24 March 2019 - 07:01 PM
Not long
Posted 24 March 2019 - 07:09 PM
Have you checked the oil level??
Posted 24 March 2019 - 07:25 PM
Your description is consistent with Big End noise, though it could be a few things.
I'll suggest checking the Valve Train first, though this normally appears as a Tapping rather than a Knock.
If it's not in the Valve Train, then regardless, it will be an engine out and engine strip to completely diagnose and repair.
Posted 24 March 2019 - 10:40 PM
Posted 25 March 2019 - 12:50 AM
Use EP90 gearbox oil and wear ear plugs.
Posted 25 March 2019 - 02:42 PM
Or like one of my neighbors just turn the radio up....
No Seriously.... the longer you leave it the more expensive it will get
