A-Plus Crown Wheel And Pinion On Pre A-Plus?
Best Answer MK1russ , 07 April 2019 - 07:44 PM
The difference is the profile of the gear teeth. A+ crownwheel & pinions do fit pre A+ gearboxes, the only modification required is when you fit a 3.2 cwp or lower (number wise not ratio), the 3rd motion bearing retainer needs to be ground back to give extra clearance.
Go to the full post#1
Posted 07 April 2019 - 07:35 PM
Posted 07 April 2019 - 07:44 PM Best Answer
