96 Spi Interior Project
17 replies to this topic
#1 thissideofparadise
thissideofparadise
  • Just Joined
  • 61 posts
Posted 08 April 2019 - 01:01 AM
I ordered a new interior for our 96 SPI from Optimise. So far the quality has been top notch and the bespoke work they did was great. They were easy to work with and the custom work was exactly what I wanted. Only complaints was how much shipping was to get it across the pond. Not Optimises fault but it still hurt the pocket book.
We ordered:
Seat covers front and back
Door cards
Door cappings
Boot liner
Gear and hand brake gaiters
Headliner
Attached File  20190325_184427.jpg   44.5K   3 downloads
Attached File  20190331_125043.jpg   59.08K   3 downloads
Day 1 Boot liner and a new carbon fiber boot. I will take more photos next time.
Attached File  20190407_135100.jpg   64.08K   4 downloads
Attached File  20190407_135111.jpg   58.51K   3 downloads
#2 RedRuby
RedRuby
  • 1,201 posts
  • Local Club: No
Posted 08 April 2019 - 12:48 PM
Looking good, will be worth it when done and then we forget the pain and expense.
#3 Steve220
Steve220
  • 4,896 posts
  • Local Club: BMC
Posted 08 April 2019 - 01:25 PM
Hopefully you won't have issues with the front door cards like most others!
#4 ajperry
ajperry
  • 316 posts
  • Local Club: Thames Valley Mini Club
Posted 08 April 2019 - 04:57 PM
Looks great! Love the quilted leather. Carbon bootlid is super cool!
Edited by ajperry, 08 April 2019 - 04:58 PM.
#5 thissideofparadise
thissideofparadise
  • Just Joined
  • 61 posts
Posted 08 April 2019 - 08:49 PM
what issues should I expect?
#6 Steve220
Steve220
  • 4,896 posts
  • Local Club: BMC
Posted 08 April 2019 - 08:57 PM
Too thick to get into the door upper recess. Mark Sharrock (total Car reviews) had real issues fitting them.
#7 roberts
roberts
    Optimise Automotive
  • 3,295 posts
Posted 11 April 2019 - 09:20 AM
We ordered:
Door cards
Door cappings
Boot liner
Headliner
Boot looks great, please make sure to send us over more photos once you have it all in!
And with regards to the front door cards...
Tom didn't have any problems with the front door cards, yes they took him longer than he was expecting (Tom thought fitting the door cards would be an easy job, it's not). He did have problems with his rear quarter panels though, but that is because his Mini has tubed rear wheel arches (meaning standard rear quarter panels don't fit).
  • You can check check out his "fitting the interior" video here: LINK
Also, whilst we are on the subject of front door card fitting:
  • Please find our door card fitting guide here: LINK
On the fitting guide you can find tips and advice with regards to the trim-clips that we recommend using and also advice with regards to getting the door cards to fit under the retaining lip (if you do have a problem with it).
Kind regards,
Andy @ Optimise Automotive
#8 Steve220
Steve220
  • 4,896 posts
  • Local Club: BMC
Posted 11 April 2019 - 01:33 PM
Odd, as they were still hanging out at Bingley, and last I saw the other week. I advised JCS custom trim to shave a shamfer in the card material at the top where it slots in to the door, this made mine fit perfectly and still retain the new overall thickness of the card. I believe Jon now does this to all his cards?
Edited by Steve220, 11 April 2019 - 01:37 PM.
#9 thissideofparadise
thissideofparadise
  • Just Joined
  • 61 posts
Posted 13 April 2019 - 09:39 PM
DAY 2 the rear interior.
Beautiful spring day here in Canada, so I took advantage of that and got stuck in. Goal finish the rear interior installation. I am nervous about doing the interior as I have never done anything with cloth in my life.
Started by taking out both front seats and gutting out the old interior.
Before I got started
Attached File  20190413_111532.jpg   33.59K   0 downloads
Old yucky door cards
Attached File  20190413_115133.jpg   69.06K   1 downloads
Attached File  20190413_115213.jpg   45.29K   2 downloads
Attached File  20190413_115252.jpg   39.85K   1 downloads
all empty, so far so good.
Attached File  20190413_120516.jpg   37.86K   2 downloads
Door cards are a pain to get in but the fit is fantastic. They slipped right under the retaining clip
Attached File  20190413_131747.jpg   40.12K   3 downloads
I shoulf of taken more photos but the bottom cushion needs to be stapled into the foam. It went well but needed a second set of hand
Attached File  20190413_132003.jpg   28.2K   2 downloads
the fit in the car was easy
Attached File  20190413_135925.jpg   44.36K   0 downloads
Now the rear back seat is attached with evil little clips. I had no idea if a special tool should of been used but ended up using pliers with one end taped up to not damage the cloth. The seat was easy to put in.
Attached File  20190413_152453.jpg   31.41K   1 downloads
Here is Rosie so far
Attached File  20190413_111518.jpg   54.07K   1 downloads
Edited by thissideofparadise, 13 April 2019 - 09:43 PM.
#10 ajperry
ajperry
  • 316 posts
Posted 13 April 2019 - 10:00 PM
Those rear seats look ace! Very nice.
#11 thissideofparadise
thissideofparadise
  • Just Joined
  • 61 posts
Posted 14 April 2019 - 12:35 AM
This evening I had a look at the front seat. Anyone know how to remove the leather from the old headrests? Also how do you remove the headrest button and know that allows the seat too lift. In other words how do take off all the plastic bit I need to remove to reskin the seats. Any videos?
#12 thissideofparadise
thissideofparadise
  • Just Joined
  • 61 posts
Posted 14 April 2019 - 11:10 PM
Day 3
Rainy day here so I moved into the garage. Tackled the front door cards and door caps.
Old door cards
Attached File  20190414_110739.jpg   40.51K   0 downloads
At first the door cards were a little too tight to fit under the slot. A quick pull on a metal ruler covered in painters tape as per Andy @ Optimise suggestion. I ended up pulling it about 1mm.and voila they fit right in. Next I used a longer tree style retainer clip which made the job super easy. About 1 hour per side including the door furniture.
Attached File  20190414_183617.jpg   23.86K   0 downloads
Attached File  20190414_135834.jpg   43.8K   3 downloads
I got door caps and installed them with heavy duty Gorilla mounting tape. I got the door caps as my drivers door came badly chipped. Not sure I love the but they door clean up the car nicely.
Attached File  20190414_141054.jpg   44.59K   2 downloads
#13 thissideofparadise
thissideofparadise
  • Just Joined
  • 61 posts
Posted 20 April 2019 - 01:02 AM
Day 4 Front seats
Since you would see them the most I really wanted to do a good job of the seat. I emailed Andy(Optimise) with a few questions that he quickly answered and gave a few tips to help me get started.
Striped of the old leather
Attached File  20190419_112947.jpg   20.7K   6 downloads
Attached File  20190419_121158.jpg   19.38K   4 downloads
Started by trying to attach the hog clips without the right tool, 30 minutes later we had only one on. Reached out to local Miniheads and someone(Hoopz Hooper)
was nice enough to lend me their pliers. I would of bought them but it is a bank holiday!
Once home we had them all on in 20 minutes
Attached File  20190419_142119.jpg   27.67K   4 downloads
Time for the clips
Attached File  20190419_145135.jpg   47.13K   1 downloads
Attached File  20190419_145138.jpg   22.69K   3 downloads
Bottom done
Attached File  20190419_145532.jpg   23.66K   1 downloads
Now the top half was easy but frustrating to get the black plastic paddle in.
Voila. The wrinkles on the pipping came out after about 2 hours.
Attached File  20190419_160203.jpg   23.25K   1 downloads
Headrests and other seat tomorrow.
#14 Wiggy
Wiggy
  • 1,036 posts
Posted 20 April 2019 - 02:58 PM
Top work. That interior looks good enough to eat.
#15 thissideofparadise
thissideofparadise
  • Just Joined
  • 61 posts
Posted 21 April 2019 - 06:18 PM
Day 5
Head rest and second seat.
Head rest are easy strip the old leather and pipping off and slowly slip the new cover on.
Attached File  20190420_091610.jpg   29.81K   2 downloads
First seat took 2 hours to finish, second took us 35 minutes. Guess we learnt how to do it properly.
Still have the head liner to do but I will wait until the summer for that.
Attached File  20190420_115016.jpg   20.14K   1 downloads
Attached File  20190421_120855.jpg   47.78K   2 downloads
Attached File  20190421_120902.jpg   25.92K   3 downloads
Attached File  20190421_120905.jpg   38.23K   3 downloads
Attached File  20190421_120750.jpg   59.92K   1 downloads
So far I would say the product is excellent and we just came back from a local show and everyone was impressed with the quality and the look. Andy if you get a few requests for seat from Canada you have me to blame!
Edited by thissideofparadise, 21 April 2019 - 06:46 PM.
