Edited by wassupcrew, 09 April 2019 - 09:24 PM.
Cylinder Head
Posted 09 April 2019 - 09:22 PM
Posted 10 April 2019 - 07:42 AM
Posted 10 April 2019 - 07:48 AM
why would it be at a different angle? all 1275 heads have the same thermostat hole orientation.
the only main difference is the casting holes or lack of. no temp take off as there is the mounting holes for the high mount alternator.
Posted 10 April 2019 - 08:10 AM
Hi all. I was wondering if anyone would know if this head would fit and work well on my 1275spi. It's a vmaxscart st3 head 36 and 30mm valves ported and polished with 19.5cc chambers. Just want to know if it would fit and work well before I invest in it ad_1554844580780.jpg
The combustion chamber cc is low compared to a standard SPI so your compression ratio will be different, you would be advised to work this out before fitting
Posted 10 April 2019 - 09:17 AM
Posted 10 April 2019 - 09:43 AM
Worth dropping Stuart at Vmaxscart an email? He might have more info on the original specs of the head. https://www.vmaxscar...nder-head-work/
Posted 10 April 2019 - 10:08 AM
Edited by Steve220, 10 April 2019 - 12:26 PM.
Posted 10 April 2019 - 10:11 AM
Edited by Steve220, 10 April 2019 - 12:27 PM.
Posted 10 April 2019 - 10:48 AM
I've moved this to a more appropriate sub forum.
A reminder for contributors, be mindful of the below statement............
Warning
Please be careful when answering peoples technical questions that you do not misguide them into taking inappropriate action. Not only is this annoying, but it can also be costly and could even be dangerous if the wrong information is given. This is why we ask that only first-hand and factual information is posted in reply to peoples queries. If you are not 100% certain of your reply, be sure to point out your uncertainty
Posted 10 April 2019 - 10:51 AM
This should clarify it.
yep a 1275 and a 998 so there are bigger issues than the stat holes.
Posted 10 April 2019 - 10:52 AM
No they don't. You try putting an MPi thermostat housing on any other cylinder head..why would it be at a different angle? all 1275 heads have the same thermostat hole orientation.
no problems I have. and it is fine. as long as it is a 1275.
Edited by nicklouse, 10 April 2019 - 11:44 AM.
Posted 10 April 2019 - 10:54 AM
What's the best way to work out the compression ratio?
..this way..
https://jscalc.io/ca...RNEglVkKLQir11T
Posted 10 April 2019 - 12:21 PM
