Hi guys, so the other day I noticed I had some very slight play in one of my rear hubs, as in if I grabbed the wheel top and bottom I could wobble it ever so slightly. It's not a lot of movement, maybe a mm, but anything is too much really.
My first though was of course a worn bearing, so I was able to source a set of genuine NOS Timken bearings from a member on here which are excellent. I've just got done fitting them, torqued up to spec, and surprise surprise, I've still got exactly the same amount of play in that wheel... I thought maybe the pin in the radius arm could be the source, but that seems to be perfectly fine, as the arm itself doesn't move. The source of the movement is somewhere in the hub.
So what could this be? My only thought is that maybe the shaft itself on the radius arm that the hub slides onto is worn? Something else to note, I can only move the wheel up and down, not side to side.
If anyone has any ideas then I'd be very appreciative!
Chris
