I've just rebuilt my rod change linkage using some 1/2" steel rods, and pressed in some new bushes, so all the slop is gone now.
Is there a better solution than the standard rubber bobbins to mount it back into the car?
https://www.minispar...ic/22G2205.aspx
I assume you can get Poly ones, but I guess these are probably too stiff?
