Hi
My mini cuts out after around 30 mins running and blows a fuse, it’s not exact and intermittent. Switch out the fuse press the switch and it’s all running again
I’ve checked the wiring all fine to the fuel pump
So I’m changing the pump hoping this is the issue.
On taking the fuel tank out there’s a part on the breather pipe I can’t see in other diagrams or in the Haynes manual, and wondered if anyone can help.
Does this need changing/servicing/cleaning as well? It’s dated and black grey part is dated would be original.
I just don’t want to refit everything and ignore it.
https://imgur.com/gallery/lnGQVl0
Fuel Pump Issues
Ian115
, Apr 10 2019 07:29 PM
5 replies to this topic
Posted 10 April 2019 - 07:29 PM
Posted 10 April 2019 - 07:36 PM
I'm assuming it's an injection?
When's the last time the fuel filter was replaced?
Posted 10 April 2019 - 07:38 PM
Yes it’s a SPI!
I brought it 6 months ago and I’m changing the filter at the same time and the pump,
from looking at the filter it was changed a long long time ago
Posted 10 April 2019 - 07:46 PM
Well that could explain it. Clogged filter means the pump has to work harder. Working harder means it draws more current. Then the fuse goes pop.
Posted 10 April 2019 - 07:55 PM
Thanks that does make sense
Do you know what the part is in the picture to see if that’ needs anything changing too?
Posted 10 April 2019 - 08:15 PM
Fuel cut off valve. I don't believe it requires any maintenance.
