Yet Another Electronic Ignition Question
5 replies to this topic
#1 Will96
Will96
  • 94 posts
Posted 11 April 2019 - 09:42 AM
Hiya all, I'm in the final stages of a 1380 build and have now turned to thinking about my ignition system, for budgets sake I'm using a reconditioned 65DM4 dizzy i already had, and have gone out and bought a DLB105 coil. Although I've just been reading through some treads to see if there's anything i need to change in my wiring (previously running standard points) and i come across someone not recommending this combination, but then not been able to find a discussion to help clarify. Just wondered if someone could elaborate.
Setup thus far:
A+ 1275 overbored
Standard compression rings (But not tested actual compression)
Evo001 cam
Hif44 carb
Standard 12g940 head (for now)
#2 nicklouse
  • 17,935 posts
Posted 11 April 2019 - 10:09 AM
wrong coil.
please read
http://www.theminifo...tributor-types/
and make sure it has a 12V feed.
#3 Will96
Will96
  • 94 posts
Posted 11 April 2019 - 10:27 AM
Thank you for the reply, so when you say wrong coil, theoretically the coil would be okay for the system but its unreliable, and the MSC105 is manufactured to better that?
#4 nicklouse
  • 17,935 posts
Posted 11 April 2019 - 10:37 AM
nope. wrong coil it will fry the amplifier.
Lucas Sports Coil
DLB 105 Suits all 12v systems with points or aftermarket electronic modules 3.5 ohms
O.E Electronic Ignition 89-on DLB198
This is the standard coil as used on the late Mini with factory electronic ignition. This was a Genuine Rover fitted part on 1275cc. GCL211 is the same equivalent as GCL143 but from Unipart. 1 ohmn
#5 Will96
Will96
  • 94 posts
Posted 11 April 2019 - 10:42 AM
Bugger... Ah well, I'll invest in a GLC143 then. Thank you for the info before i started breaking things
#6 whistler
whistler
  • 1,703 posts
Posted 11 April 2019 - 03:37 PM
GCL143 coil and open up the plug gap to recommended for 92 cooper with same setup.
