Torque Wrenchs
31 replies to this topic
#31 nicklouse
  • 17,944 posts
Posted 13 April 2019 - 08:46 PM
Ok some pics and some reasoning.
the new wrenches
zmahGCn.jpg?1
as you can see the smaller wrench is just a 3/8ths with a stepped bit.
KbMbOus.jpg?1
the old SP ones
LPjISor.jpg?1
and the issues
setting the numbers is a bit hit and miss. and there is no lock and the graduated scale is a label.
on the small wrench the line is also printed on a clear plastic film
if that gets a hole in it....
so after me seeing how they compare using bolts and nuts and pointers i would say there is nothing really wrong with the old ones except they could easily become unusable.
and finally the baby.
for use on cycles.
oh and i gave the old wrenches a clean out on the ratchets.
one thing you should also consider when buying a torque wrench if they are normally only calibrated for use in one direction. so the flippy lever you see on many is rather useless...
#32 DeadSquare
DeadSquare
  • 2,767 posts
Posted 13 April 2019 - 09:24 PM
Now engrave on both sides  "Stolen from Nicklouse" and a phone number.
