Loom Identification For A Hybrid
Posted 13 April 2019 - 07:00 AM
Following on frrom my introduction, here - http://www.theminifo...792-old-newbie/
I am in the process of trying to pinpoint which loom I should be purchasing to replace what is currently in my car.
I called on of the specialist Mini places but I wasn't filled with confidence when he gave me a part number on the phone, lots of umms and ahs while I gave him the required information.
My car is registered as a 1971 Clubman with a 1275 engine but what I don't know is what car the loom was from if it was built using parts from a similarly aged Cooper S.
Can anyone guide towards a new car loom that would need the fewest changes. My car currently has these items -
Column Ignition
One column stalk (indicator, dip main and horn)
Alternator
4 fuse holder (can this be changed to two to suit?)
Heated rear window (not a show stopper if not available)
Centre 3 dial dash
Toggle switches in centre
The chap on the phone from the Mini parts place identified the part number 5L1331 as the closest to what I need. Do the learned members of this forum agree that this is the closest or the correct option?
Thanks in advance.
Posted 13 April 2019 - 09:48 AM
so what engine is it? as that has more to do with the harness than most things as an A and A+ has a big effect on what is needed. changing from a 998 to a 1275 has no change of harness if the same engine type.
see nothing Hybrid from your description.
Posted 13 April 2019 - 10:26 AM
Plenty of Hybrid in the wiring.
Column Ignition 69>
One column stalk >76
Alternator 69>
4 fuse holder 76>
Heated rear window Not sure when it became an option but I have seen an add on extra loom and switch .
Centre 3 dial dash Not Clubman 61-76
Toggle switches in centre Spade connectors the same as early rocker switch so 59-76
So apart from the 4 fuse holder I would think part number 5L1331 will do the job.
Posted 13 April 2019 - 11:57 AM
"see nothing Hybrid from your description"
Not even this? - 1971 Clubman with a 1275 engine but what I don't know is what car the loom was from if it was built using parts from a similarly aged Cooper S.
My introduction has more details but basically, the original owner had a Cooper S but had an accident. The remnants of the Cooper S were built into the Clubman body. What I don't know is how much of each was used to form what I have here.
It's a learning process, I'll get there.
