Fitting Verto Clutch
Posted 13 April 2019 - 11:40 AM
Posted 13 April 2019 - 11:41 AM
nope it does not pop. if it has you may well have fitted the offset key washer incorrectly.(so now it will need replacing).
PS use a torque wrench not a bar so you know you have done it tight enough.
Posted 13 April 2019 - 11:44 AM
Posted 13 April 2019 - 11:46 AM
I guess you are talking about the large bolt that goes into the crank? It needs to be lined up with the crank with the key washer and then torqued to I think 115 foot pounds,Check in your haynes manual.
Posted 13 April 2019 - 11:49 AM
No it didn't "pop" on I was just expecting it to so its confused me mate er what about the little cog that's meant to engage with the fly wheel should they not be together? Currently it looks like it's sat behind
you mean the offset key washer? nope if they make everything flat then you are buggered.
Posted 13 April 2019 - 11:54 AM
Posted 13 April 2019 - 11:56 AM
Posted 13 April 2019 - 11:58 AM
Posted 13 April 2019 - 12:02 PM
Can you confirm that you have installed it with the offset key installed correctly with the crank and flywheel boss all alligned?
Posted 13 April 2019 - 03:52 PM
Posted 13 April 2019 - 03:54 PM
