I am in the process of fitting a jig to my shell and have just removed the front subframe and laid up the fixing bracket that attaches to the large subframe bolts. The problem is this fouls on the bolts that retain the master cylinders and pedal box. How do these actually come out? Do I just knock them down or are they welded to the pedal box? I don't want to hit anything excessively if I don't need to, so any advice would be appreciated.
Column and pedals are already removed, as are the two horizontal bolts that go into the bulkhead.
