I have most of it in place but could do with a little help on a few areas.
First - fitted to the drivers side inner wing are 3 relays and a black inline fuse. The inline fuse and one relay appear to be a separate circuit to the main loom. Mr Haynes says this is for rear fog lights but i cant figure out how the wire coming from this circuit would connect to the rear fogs ? I could see it being front spots but not rear fogs? Attached to this wire are 2 plastic connector with blue and yellow and a black wire to each.
Second - next to the fuse box (24pin) there is a brown wire and a white wire not connecting to anything.
Does this brow wire connect to the brown connection on the circuit described above ? But what is the white connection for ? Ill try to sort photos
Anyone know what this is for ? Thanks Jon
Edited by Sprok, 15 April 2019 - 06:41 PM.
