Spi Wiring Help?
#16
Posted 01 May 2019 - 06:05 PM
Anyone help
#17
Posted 03 May 2019 - 12:23 PM
#18
Posted 03 May 2019 - 02:57 PM
Im confused (sorry about that) but why do you need to get those out of that plug in tact? Will those pins fit into a harness plug that you want to use? What is the preferred end connector type?
#19
Posted 05 May 2019 - 11:17 AM
Was working on my dashboard yesterday so got a chance to have a good look at that plug.
The yellow insert comes out quite easily and than you can release the pins individually.
There are two rectangular holes in the side of the yellow plastic.
Place a small flat screwdriver in the hole and lever it outwards gently, it moves easily without too much force.
Once out you will see a small plastic catch on each pin.
#20
Posted 11 May 2019 - 09:39 PM
Ive just ordered new pins to attach instead of the bullet connectors on my rear loom. Should make a factory fit job.
Thanks all
#21
Posted 16 May 2019 - 03:15 PM
#22
Posted 17 May 2019 - 09:41 AM
Is there a brand name on the plug ?
