The one behind the inner pot joint.
There is a detent spring under the plate but should it have a detent pin or ball on top ???
DavidR
5 Bolt Diff Retaining Plate
Fastorq
, Apr 15 2019 07:54 PM
4 replies to this topic
Posted 15 April 2019 - 07:54 PM
Posted 15 April 2019 - 07:56 PM
Posted 15 April 2019 - 09:25 PM
Sh*&.
Never saw that coming ... but think I heard it going!
Is the ball at the bottom of the sleeve or at the top
Ie
Under the spring or on top of the spring ... can’t see any reason why it should be at the top under the plate?
Ie
Edited by Fastorq, 15 April 2019 - 09:45 PM.
Posted 15 April 2019 - 09:46 PM
DavidR
The Ball is inside, not directly under the cover. You need to remove the spring first, then the ball is under that.
Posted 15 April 2019 - 09:56 PM
Maybe I’m ok then.
There was a noise of something hitting the bench just as I moved the plate to the side and the spring popped up.
Coincidence?
Spring didn’t come out of the hole / sleeve so ball must still be down there
Will check that tomorrow
Thanks both for your help
Regds
DavidR
Must buy a workshop manual for a 96 car.
Coincidence?
Regds
DavidR
Edited by Fastorq, 15 April 2019 - 09:58 PM.
