Is there a simple way to figure out how many studs I have? Is 9 standard for a 998?
I want to learn to do the valve timings and im wondering if I need a 9 or 11 stud silicone rocker cover gasket...
Would both work?
Engine Studs, How Many?
Posted 16 April 2019 - 06:45 AM
Posted 16 April 2019 - 06:46 AM
9
Posted 16 April 2019 - 07:44 AM
an 11 stud head would have an extra fixing visible at each end of the rocker cover; one by the heater take-off and one by the thermostat housing
Posted 16 April 2019 - 10:48 AM
Don't only 1275 heads have an 11-stud version?
Edited by gazza82, 16 April 2019 - 11:12 AM.
Posted 16 April 2019 - 02:59 PM
I'm pretty sure that the 970cc and 1071cc "S" engines had 11 studs as well. Mind you, you don't fall over too many of these in 2019.
Posted 16 April 2019 - 03:13 PM
But weren't the 970 and 1071 "big block" engines too?
Posted 16 April 2019 - 08:56 PM
Only the original Cooper 'S', 970, 1071 & 1275, had 10 studs plus one 5/16" unc bolt. That applied to the Mk.1. 2 & 3 versions.
Everything else has 9 studs.
