Edited by stumpy75, 16 April 2019 - 10:58 PM.
Anyone Local Got A Spot Welder
Posted 16 April 2019 - 10:56 PM
Posted 17 April 2019 - 08:08 AM
What power supply do you have, on which to run it ?
Posted 17 April 2019 - 03:10 PM
Posted 17 April 2019 - 04:20 PM
Sorry, in that case I can't help.
You are correct, some are single, but I don't think that they will run off a 13 amp fuse.
Posted 17 April 2019 - 07:05 PM
Posted 17 April 2019 - 08:28 PM
I know in our parts, there's many shops that will rent them for very reasonable rates.
Posted 17 April 2019 - 11:15 PM
Regards 3 phase my mate has an industrial unit 5 minutes down the road i could if need be get the tub down there to use his supply
Posted 17 April 2019 - 11:22 PM
I MIG-welded a roof panel on by plug welding. I drilled 5 mm dia holes avery 25 mm in the roof panel flange and welded a few at a time next to each other before moving to a different area.
With regard to grinding back, I used a new grinding disc and held the wheel vertical. After grinding, I got a pot of fibreglass liquid resin and hardener and used a small paint brush to 'paint' it onto the ground back flange. I didn't rub that back and it looked just like the original roll-welded process. After painting the roof it did/does look very original.
Posted 18 April 2019 - 07:24 AM
Ive phoned a few around here no one seems to rent them
Regards 3 phase my mate has an industrial unit 5 minutes down the road i could if need be get the tub down there to use his supplySorry, in that case I can't help.
OK.
I'll go and see my friend tonight, I'm sure he'll lend it over a W/E.
It is heavy, and takes two to lift it out of the pick-up.
Sods law, the plug will be wrong, as his is 40 year old metal Lewden.
Posted 18 April 2019 - 07:46 AM
Sounds like the plug will be wrong for that size. You can buy a single phase spot welder in machine mart.
Posted 18 April 2019 - 08:44 AM
My friend's isn't one of those great heavy things that knacker your arms after 5 spots.
His is a big transformer and a maneuverable gun that you position, lock, trigger and the timer releases.
It even has a simple gauge that you center on the last spot, so that they all come out equidistant.
Posted 18 April 2019 - 10:46 AM
ime a powerlifting champion dont worry regards the weight haha
Posted 19 April 2019 - 08:56 AM
Eph you sea kay the EU.
I spoke to my friend last night, and he said that he would willingly have helped you this week end, ... but ... all his welders now have to be in a screened area, and so that they can not be moved and used outside that area, the must be hard wired.
Sadly, because his size of business has been brought under the more strict regulations, I can't help you. I am very sorry.
Posted 19 April 2019 - 11:01 AM
Posted 23 April 2019 - 07:24 AM
