Hi Everyone,
I have a couple of possibly simple or dumb questions;
1) So I replaced the sintered rockers on the car with a set of oval pad pressed rockers (I think they came locally on the GTS). I was wondering if I need to adjust the carb fuelling too as the idle on startup is a bit shaky?
2) I fitted a set of budget finned drums from Minispares at the rear and there's a scratching sound when I turned the wheel. Looking at the back face of the drum it didn't appear to be touching the back plate and I was wondering what it might be rubbing against and how I might be able to fix it?
3) I asked a friend for some help and we fitted new handbrake cables as the old ones were very stretched. We swap them out and once fitted we adjusted the brakes and then the handbrake, but even after almost fully compressing the springs it isn't particularly effective. I was wondering if the solution is that I should get new rear brake shoes?
4) The rear view mirror suction cup thing was not sticking anymore so I bought a new one from Minispares, and it keeps popping off. How do I get this to stick properly?
Thanks for the assistance :)
Vinay
