Close Call: Full Breaking Spun Me 90*
18 replies to this topic
#16 luismx123
luismx123
  • 525 posts
Posted 18 April 2019 - 09:14 AM
Can we assume there's a FAM7821 brake valve hiding under the servo? If there is your only options are smaller wheel cylinders or replace it.
Of course, lacking ABS, there's always the possibility of locking up the rear particularly on loose or uneven surfaces. Start by servicing and checking the rear brakes, handbrake cables... They can get out of balance pretty easily.
"IF there is, your only options are smaller wheel cylinders or replace it". it - as in the brake valve? I had the rears serviced by myself and a mini maniac guy I know. Pads were evenly worn, one of the retention springs were put in wrong causing them to wear so we replaced that. Gave the whole area a proper de-dusting and clean. Checked for leaks etc. Handbrakes cables also looked at. Holds tight at 2-3 clicks. Did that all according to haynes.
Ill try some moderate full brake scenarios this weekend/over easter to find out if it was a one off thing or not, which direction it spins, if the tires lock etc. Still need to read up on calverst' article.
#17 DeadSquare
DeadSquare
  • 2,767 posts
Posted 18 April 2019 - 09:28 AM
There are two simple remedies.
One is to drive slowly, which is no fun.
The others is to coat the brake shoes with grease.
When racing in the wet, I used to put a little leather washer into the brake cylinder before screwing in the brake pipe.
#18 Ethel
  • 25,416 posts
Posted 18 April 2019 - 08:16 PM
Yes, it being the brake valve. It will block off the rear line when the front reaches the specific pressure to operate it. So that pressure multiplied by the wheel cylinder piston area is your maximum rear braking effort.
The other approach is to alter the line pressure needed to operate the valve, The FAM7821  won't do that, but Wilwood make a valve that fits similarly.
#19 Ivor Badger
Ivor Badger
  • 846 posts
Posted 18 April 2019 - 08:29 PM
