Hi there I’m relatively new now to owning a mini. I’m 17 and I am restoring a mini to be my first car. The mini just won’t start I had the engine out to do the clutch, it’s been put back in everything plugged in and earths reattached.everything seems to be working although it will not start, I have tried bypassing the ecu to check if that was the problem but it gets spark and fuel, with starter motor working fine with correct volts to it. I’m replacing the crank position sensor next week although I can’t see that being the problem, I’m very lost now, any suggestion. Cheers will
Classic Mini 1275Cc Sprite Spi Not Starting
Williambeee
, Apr 18 2019 09:26 PM
No replies to this topic
