Lack Of Fuel In The Injector
#16
Posted 19 April 2019 - 05:00 PM
#17
Posted 19 April 2019 - 05:07 PM
What happens if you hold the meter on both the grey and yellow wire, whilst cranking? Trouble is, I doubt the meter can update quickly enough to register the pulse, but you never know. I'm guessing the yellow wire is the switched earth in the ECU.
The injector could just be clogged, too.
#18
Posted 19 April 2019 - 05:09 PM
#19
Posted 19 April 2019 - 05:18 PM
Just looking how to do this. There is a square retaining plate with 4xT20 bolts holding it down then the yellow cap with 1 bolt.
Presumably clamp fuel lines and undo all 5 bolts or do i need remove the whole injector housing (top bit) ? I see thats held down by 4 x T30 bolts.
Hope you can help
#20
Posted 19 April 2019 - 05:54 PM
Remove injector connector cap retaining screw. (That's the single Torx).
Use a rag to mop up any fuel.
Lift cap off.
Lift out injector.
Edited by Wiggy, 19 April 2019 - 05:57 PM.
#21
Posted 19 April 2019 - 06:27 PM
#22
Posted 19 April 2019 - 07:08 PM
Ok, go back a couple of steps. I am not up on all the SPI details but reading out of the second PDF link I previously posted, the ECU cycles the earth wire and not the power. So, to check for pulses you need to connect your voltmeter to both injector wires and if my brain works right, your voltmeter will read nothing on DC but when you switch to AC it should read some voltage.
#23
Posted 19 April 2019 - 07:28 PM
Got the injector out - its spotless. Not alot to clean?
What is the little motor looking thing next to the injector ? Is it a mini pump ?
#24
Posted 19 April 2019 - 07:42 PM
I think the other object is a pressure regulator maybe its that?
#25
Posted 19 April 2019 - 07:47 PM
Electrics just not my forte. But ill have a play and try and do that
It is probably the pressure regulator. If it is, it has a diaphragm and a spring (similar to mechanical fuel pump). If the fuel pressure is too high, the diaphragm pushes against the spring and opens the bypass to the fuel return line. The thing to check on the injector is the continuity through the coil on both terminals for the connector. It should read very low next 0 Ohms. If it reads infinity, the coil is open.
If the 3.4 volts was AC, it looks like the ECU is sending the pulses to the injector.
#26
Posted 19 April 2019 - 08:17 PM
It's the inside that gets clogged with dried up fuel residue. You won't be able to see it. The professionals ultra-sonically clean them.
I have used a small syringe full of Unleaded, pushed into the injector with the plunger pushed hard to create pressure; then pulsed the injector with a 12V supply. Worked very well.
#27
Posted 19 April 2019 - 08:50 PM
That sounds like good idea. Carburettor cleaner spray would probably do the job too.
#28
Posted 19 April 2019 - 08:53 PM
Does anyone still sell the injector housing complete?
Think the easiest thing would be a replacement ?
#29
Posted 19 April 2019 - 09:20 PM
Well, there should not be an accelerator pedal switch on a 96, there is no radiator temp sender, the coolant temp sensor is underneath the intake manifold and even if disconnected the engine would run in "limp mode". If there is no crank sensor, there is no injection and no spark.
I don't think you can get a new injector housing anymore.
#30
Posted 19 April 2019 - 10:20 PM
Crank case sensor is wired up or i guess it would run with fuel poured into the throttle body?
How can i test the fuel pressure regulator ? I took the cover off but the unit seems to be bonded into the housing?
