Has anyone made or bought the bracket that later subframes have on the front subframe for gearbox to front of subframe lower stabilizer?
I know most if not all rubber mounted subframes have a welded in bracket but I'm looking to add one to a 2 bolt subframe on a Mk1.
I also have a broken bracket on my wife's '83 which I need to replace, so a new one is needed for that car as well. A drawing would be useful as I don't have a pattern if these are not made.
http://www.minispare...ic/FAM2758.aspx
This picture is from a similar query.
Taken sideways, it's the bracket that the bolt goes through that is welded to subframe crossmember.
Edited by whistler, 23 April 2019 - 09:54 AM.
