Best Answer
richmondclassicsnorthwales
29 April 2019 - 05:30 PM
Hi
Well, not too bad, normal for a Mini
Crack on and fix the front ball joints and track rod ends in one hit. I sell a kit for that and this is it below. Same parts as supplied by MiniSpares
https://www.richmond...60838&id=751423
Rear wheel bearings should take some grease, always overlooked, so pop off the grease caps and get some grease in. Pop the cap, remove the split pins and unscrew the nuts. Pop some grease on the bearings and roll them by hand to get the grease circulated, not too much grease !.
Fog lamp will be connections, so check the bulb first for filament, then check the electrical connections and importantly the earth. Don't forget your lights need to be on before checking the leads / connections for the fog lamp
Afternoons work should see you done. I would have thought the garage would have adjusted the headlamps on the test unless the adjusters are seized up. Not the biggest of jobs, a minute each if that under the beam check. Have a look at these yourself to see if they are seized. If not, leave off the headlamp rims and I am sure they would aim these Free of charge. Use a bit of WD40 if a bit stiff
Go to the full post
