Blowing Holes...
14 replies to this topic
#1 projectjordan
projectjordan
  • 88 posts
  • Local Club: southwalesminis
Posted 01 May 2019 - 02:45 PM
Hi all
I'm trying to weld a patch into some bodywork (not a mini), and i'm using the owners SIP 181DP.
This is what I'm getting on the lowest setting with 0.8mm wire on CO2, have I set it up wrong?, or is the welder just too powerful for the job?? Both sides of the metal are clean and rust free. I'm not the best welder in the world, but I'm usually able to do better than this, with either my clarke 135 or older sip 150.
cheers
Ryan
59008936_10157093739141878_8988845205922
59553841_10157093739491878_9021156597077
#2 projectjordan
projectjordan
  • 88 posts
Posted 01 May 2019 - 02:49 PM
Looking at the images as I post them, I may have missed the obvious...
Edited by projectjordan, 01 May 2019 - 03:01 PM.
#3 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 15,899 posts
  • Name: Neil
Posted 01 May 2019 - 04:16 PM
More wire speed should do the job
#4 stumpy75
stumpy75
  • 291 posts
Posted 01 May 2019 - 05:48 PM
I have mine set up so that it blows holes after a 10 mm run i then pulse weld penetration is great and the welds are low and flat wich means less dressing/linishing
#5 Daz1968
Daz1968
  • 2,058 posts
Posted 01 May 2019 - 06:02 PM
Is it set up with torch to negative as well, if so I think that is usually for gas less, I agree with points above though as the wire feeds to slow, it’s just striking up and blowing the material away,
#6 Homersimpson
Homersimpson
  • 803 posts
Posted 01 May 2019 - 06:40 PM
Definitely more wire speed needed.
#7 Broomer
Broomer
  • 1,771 posts
Posted 01 May 2019 - 10:39 PM
Oh its about welding, never mind.
#8 elf66
elf66
  • 55 posts
Posted 02 May 2019 - 08:49 AM
Try 0.6 wire and increase the feed speed at a lower power. Looks like you may need more gas as well.
#9 nicklouse
  • 17,945 posts
Posted 02 May 2019 - 09:02 AM
go on then what did you spot?
#10 Icey
Icey
  • 1,493 posts
Posted 02 May 2019 - 12:09 PM
0.8mm wire is too thick for this really. Switch down to a 0.6 wire, increase the wire speed and decrease the amps.
You'll still probably find it hard to stitch a 'bead' of weld on such thin sheet, I'd suggest looking at the pulse weld techniques instead.
#11 projectjordan
projectjordan
  • 88 posts
Posted 02 May 2019 - 01:06 PM
It looks like it is set at 1 on power setting. It’s actually on 7!!
#12 sonikk4
sonikk4
  • 15,899 posts
  • Name: Neil
Posted 02 May 2019 - 01:08 PM
Well that will be why then
#13 nicklouse
  • 17,945 posts
Posted 02 May 2019 - 01:35 PM
that's what I was thinking. but thought no he cant have done that.
#14 1293gt
1293gt
  • 306 posts
  • Local Club: nonw
Posted 02 May 2019 - 04:25 PM
Hahahah!!!!
#15 tiger99
tiger99
  • 8,584 posts
Posted 18 May 2019 - 12:32 AM
If the polarity is wrong, as for gasless, you MUST correct it or you will never get correct welds.
If in doubt (and even if not in doubt because it is a useful resource for many things) I suggest looking at the MIG welding forum.
https://www.mig-welding.co.uk/forum/
You will even find info there on welding certain French vehicles with much thinner steel than the Mini, and almost as many good qualities.
