Spi Horrific Wheel Shake At 65
Best Answer phillrulz , 04 May 2019 - 06:27 PM
Right, what  was behind is now infront and what was infront is now behind.
With a quick 90mph blast up the A40.... I Can happily say not a single steering wheel wobble.
Looks like i have a bad alloy. Guessing driver side as i had previously swapped passenger side as i stuck the car in 1st on axle stands and let the wheel spin passengers side looked more wobbly.
When my local tyre shop moves premises ill take the rear allows over for an inspection, weird thing is they didnt look too bad.
Weird how the bloke balanced them today one was showing like 10/55 and one like 20/65.
Go to the full post
18 replies to this topic
#1 phillrulz
phillrulz
  • 617 posts
Posted 04 May 2019 - 02:50 PM
Hi guys, long time since i had the mini upto motorway speeds, but did today.
Shes got a nasty shudder at 65+ like steering wheel and front end, its shaking my calves. Steering wheel bounced left and right maybe 1" no real bias in which way it wants to bounce seems to go from left to right and remains straight.
  • Wheel bearing have no play
  • ball joints have no play
  • both U bolts still present and tight
  • tyre pressures all good
  • wheels balanced
Going to try swap front for rear.
I saw something about checking steering bushes, where are these?
#2 cal844
cal844
  • 9,488 posts
  • Local Club: TFMOC
Posted 04 May 2019 - 03:11 PM
Check the holes in the wheels are actually round. I have a set of 10 inch Rostyle wheels that are scrap because the stud holes have been ovalled
#3 unburntfuelinthemorning
  • 1,915 posts
Posted 04 May 2019 - 03:36 PM
When were the wheels balanced?
#4 whistler
whistler
  • 1,706 posts
Posted 04 May 2019 - 04:08 PM
Check that the wheels have the same PCD as the studs. I have found wheels with a PCD of 100mm fitted onto Minis which should generally be 101.5mm (4 inches). This can cause wheel wobble as well as damaging the wheels/studs.
#5 phillrulz
phillrulz
  • 617 posts
Posted 04 May 2019 - 04:59 PM
Thanks for replies guys
Sorry for delay. Just swapped the wheel that looked bucked for a spare. Still have the shake. Think ill swap rear for front
https://puu.sh/DnM6b.png
https://puu.sh/DnM7u.png
Look okay to me
Today as i thought may fix, it out a fair bit but still shakes
They are minilite type alloys so assuming its the imperial not metric PCD
#6 cooperS
cooperS
  • 116 posts
  • Local Club: MOC Santiago, Chile
Posted 04 May 2019 - 06:14 PM
check the pitman arms it may be one of the bolts broken
#7 phillrulz
phillrulz
  • 617 posts
Posted 04 May 2019 - 06:24 PM
Checked bothsides they were fine both bolts felt more like studs then bolts but still solid
#8 A-Cell
A-Cell
  • 1,610 posts
Posted 04 May 2019 - 06:26 PM
LOL. I assume you mean the steering arms on each hub.
Mini has a steering rack. It does not have a pitman arm!
#9 richmondclassicsnorthwales
  • 942 posts
Try track rod ends, see if there is any play
#10 A-Cell
A-Cell
  • 1,610 posts
Posted 04 May 2019 - 06:27 PM
Get the wheels balanced again. Maybe you list a wheel weight or weights. Or they were never done properly before.
#11 phillrulz
phillrulz
  • 617 posts
Posted 04 May 2019 - 06:27 PM   Best Answer
#12 phillrulz
phillrulz
  • 617 posts
Posted 04 May 2019 - 06:30 PM
First thing i checked, as for prev MOT had to change steering rack gators i had track rod ends off. Both good issue solved
I got them balanced today as i had the vibration, it didnt help at all. After swapping front wheels for rear its done so an Alloy is buggered will get it looked at by the guys i trust.
#13 A-Cell
A-Cell
  • 1,610 posts
Posted 04 May 2019 - 06:35 PM
Glad you narrowed it down. Out of round wheel!
#14 phillrulz
phillrulz
  • 617 posts
Posted 04 May 2019 - 06:36 PM
Must be, i checked both by letting the wheels idle around in first, however passenger side looked worse.... owell no more death shakes for me
Cheers for helping
#15 whistler
whistler
  • 1,706 posts
Look okay to me
Never assume where a Mini is concerned.
