Front Knuckle On Hydro Question
Best Answer johnv , 08 May 2019 - 04:59 AM
Passenger side steering arm Bush? Go to the full post
Posted 05 May 2019 - 09:37 PM
Thks
Posted 07 May 2019 - 07:20 PM
If there are shock absorbers fitted these are non-standard. I would suggest first taking these off and see what effect this has on the banging noises.
Also if you're taking it down rough roads I would highly recommend fitting the competition front bump stops to give the dspacers an easier time and longer life. Here the link to the Minispares kit C-AJJ4007: https://www.minispar.../C-AJJ4007.aspx
Posted 07 May 2019 - 08:29 PM
I'm not sure the issue here would be the knuckles and I agree with Carbon's suggestions.
Usually Knuckles squeak (and quite loudly) when they are worn.
Posted 07 May 2019 - 11:28 PM
Posted 08 May 2019 - 04:59 AM Best Answer
Posted 09 May 2019 - 07:23 AM
John makes a good point.
Zami - have you checked the steering rack has correct amount and grade of oil in it? This bush can rattle over rough tracks if the oil level gets low.
Posted 10 May 2019 - 08:20 PM
Posted 10 May 2019 - 08:23 PM
Posted 10 May 2019 - 08:25 PM
it says i can’t upload this audio file, .m4ahere is the audio. starts around 40 sec. in.
Posted 10 May 2019 - 08:29 PM
Posted 10 May 2019 - 08:54 PM
carbon, i will check steering rack oil. are there bushings both sides as the noise is coming from both.
The Bush is only on the passenger's side.
Posted 10 May 2019 - 09:13 PM
Jacked up front of car held each wheel at the 9 and 3 o’clock position. Noticed on drivers side no play but on the passengers side I can move the wheel maybe 1/2”-3/4” before steering wheel turns.
Posted 10 May 2019 - 09:23 PM
That does sound like it could be the bush and most likely is.
Just before rushing in to overhauling the steering rack, check the Steering Rod End and that the Steering Arm where it's bolted to the Hub is tight first.
Posted 10 May 2019 - 10:39 PM
I am concerned that since I am getting the exact sAme noise from both sides that I may have some other issue. Tomorrow I will go back around again to check that everything is tight including the ams to hub.
Posted 14 May 2019 - 01:41 AM
it turns out that it was the bushing on the passenger side of the steering rack. Once I released the steering rod bearings End I could duplicate the noise in the foot wells. Way to much play. Thanks again for everyone’s input.Passenger side steering arm Bush?
