This was at idle
Screenshot_20190505-144902_MEMS Diag.jpg 26.31K 1 downloads Screenshot_20190505-144919_MEMS Diag.jpg 27.82K 0 downloads
Edited by thissideofparadise, 08 May 2019 - 01:07 AM.
Posted 08 May 2019 - 01:05 AM
Posted 08 May 2019 - 06:28 AM
This is only a momentary picture of the values. It is getting interesting if you do a logfile. I know it is difficult to export the logfile.But you can send it to your pc and import it in excel.Then you may diagnose it. More interesting is to open it in mems-rosco within readlog. But some values like gps_speed,v-maf,v-fuel,vtotal fuel and v-fuel will not be shown there.By the way, which value is unclear. (Tune-timing,tune-idlerpm and u-load is unclear for me too) But there is a forum for mems-diag too.
This is an example what you will see if you import the log-file in excel.
Posted 08 May 2019 - 03:24 PM
Posted 08 May 2019 - 09:22 PM
is is a temp measurement or quantity.Coolant looks low,should be near to 88c
Posted 08 May 2019 - 09:23 PM
log file sounds cool but I have no idea what the readings mean. any clues on that?This is only a momentary picture of the values. It is getting interesting if you do a logfile. I know it is difficult to export the logfile.But you can send it to your pc and import it in excel.Then you may diagnose it. More interesting is to open it in mems-rosco within readlog. But some values like gps_speed,v-maf,v-fuel,vtotal fuel and v-fuel will not be shown there.By the way, which value is unclear. (Tune-timing,tune-idlerpm and u-load is unclear for me too) But there is a forum for mems-diag too.
Posted 08 May 2019 - 10:19 PM
it should be the temp of the coolant which should be near to 88c ,have you let it warm up ,have you got the correct thermostat fitted?
Edited by hunterg30, 08 May 2019 - 10:20 PM.
Posted 09 May 2019 - 01:18 AM
it should be the temp of the coolant which should be near to 88c ,have you let it warm up ,have you got the correct thermostat fitted?is is a temp measurement or quantity.Coolant looks low,should be near to 88c
Posted 09 May 2019 - 05:46 PM
Posted 09 May 2019 - 05:57 PM
Read haynes and get familiar with the ecu.
Edited by genpop, 09 May 2019 - 06:01 PM.
Posted 10 May 2019 - 01:13 AM
