16v head dropped onto my block to et an idea of sizing/ clearance
Fiat 1.2 16V/8V Head Conversion
#16
Posted 09 May 2019 - 12:21 PM
#17
Posted 09 May 2019 - 12:27 PM
also I "think" the 1.4 shares the same head gasket, so this could open up the avenue to use the late head and map the cam timing.
Posted 09 May 2019 - 12:55 PM
In the third pic, how much does the head overhang the front of the block, and is it overhanging at the flywheel end as well ?
#19
Posted 09 May 2019 - 01:50 PM
Front edge is around 10mm - 1/2" about had if the oil drain holes are exposed, but they are round so you could plug them and tap a hose into the side if the head and drain into the dizzy hole, the end of the head over hangs, but it's all the cam drive gears, nine if the gasket hangs over.
#20
Posted 09 May 2019 - 01:59 PM
well, i have checked this out but it was a couple of years ago,
That is a pretty good fit, and most of the studs are not far out.
#21
Posted 09 May 2019 - 02:08 PM
Come in I'm not gonna do all the hard work for you
Thanks for the info.
It is enough to encourage me to go and find a Fiat head.
Meanwhile, I am "working hard" to put a single overhead cam on my CAM 4810 head
#22
Posted 09 May 2019 - 03:22 PM
#23
Posted 09 May 2019 - 04:15 PM
Please may I beg one more bit of "hard work" from you ?
How long is the block casting ?
#24
Posted 09 May 2019 - 09:29 PM
#25
Posted 09 June 2019 - 07:24 PM
I had a chance to look over the information shared regarding this conversion. I thought I might try and get a few answers to some questions I have. (some stupid I’m sure)
Attached it a pic with the required mods to the Mini block.
Yellow- Stud positions. The centre bolt also which looks to like up very conveniently. Good start!
Blue- these are the positions for the waterways to the Fiat head. If these are drilled in the block will they find the Mini water jacket ok?
Red- Oil drains from head to the block. Will using 2 of the 6 be sufficient?
Can the rear 2 be drilled through the block into the oil gallery at the back of block? Or better off running externally to the fuel pump hole.
On the front 2 it looks like these will need to be run externally down front of block to the Dizzy hole?
Green- 2 oil drains from head to be blocked and unused.
Robert on his conversion used the Mini gasket. Is there any reason the Fiat gasket couldn’t be used saving the need for modifying the mini gasket?
