Upgrading Fuse Box To Blades
6 replies to this topic
#1 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 08 May 2019 - 07:04 PM
I've already read the posts but I am still confused about which ones to use i think i have it figured out:
1989 Mini 4 glass blade fuse box:
Top Glass: 35A Blade: 15A
Second Glass: 25A Blade: 10A
Third Glass: 25A Blade: 10A
Bottom Glass: 15A Blade: 5A
From what i can figure out you divide in half and then round down. Please let me know if i'm going wrong somewhere :)
#2 nicklouse
  • 19,062 posts
Posted 08 May 2019 - 07:12 PM
Have a read http://www.theminifo...ou-need-to-know
#3 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 08 May 2019 - 07:15 PM
I'd say the only change to that is a slightly higher amperage on the top and bottom fuse, so 20 amp Blade fuse and 10 amp Blade fuse in the bottom fuse.
By the way Halfords do a glass fuse kit with multiple ratings.
#4 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 08 May 2019 - 07:49 PM
i'm only changing because im bored of having to take the fuse box off take it apart clean it and put it back together :) Thanks for your help :P
#5 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 08 May 2019 - 08:14 PM
I've never had to take mine off to clean it, I do flake all the corrosion off then smear it lightly in grease.
I don't have the sound deadening foam behind the fuse box
#6 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 08 May 2019 - 08:41 PM
I don't either but i have to do it once or twice a year so upgrading and hoping for the best :)
#7 BaronVonchesto
BaronVonchesto
  • 531 posts
Posted 10 May 2019 - 10:36 AM
If you're gonna switch to blades might i suggest you do it properly and rewire your car so that every circuit has it's own fuse instead? It's not how minis were ever wired from the factory, but It will be far safer and easier in the future.
