Parts from a mini 30 project.
Sadly I need the space and no longer have the time to complete it
Engine and gearbox - 998cc
Its all dismantled but all parts should be there, i can include all the ancillaries. carb and standard air filter too. radiator, and gear linkage etc.
Shell
I was planning on replacing the whole front end, so front panel, wings and scuttle are cut out. The RH door step is also cut out. Doors and boot are there, no bonnet.
The bottom has all been stripped of muck and the sound deadening stuff inside on the floor has been removed.
Looks like there is rust hole in one of the rear bins.
V5 and vin plate are present.
Link to some photos: https://flic.kr/s/aHskTeyMpA
Ideally to go in one lot - £300
Location is GU24 postcode, pickup only.
