Removing Flywheel
35 replies to this topic
#1 JDImini
JDImini
  • 683 posts
Posted 11 May 2019 - 11:11 AM
I have what I think is a '79 1098 engine which I'm planning to strip down and possibly rebuild for fun over time.
I've got the the stage of trying to remove the flywheel but it's not shifting. I've got pistons No.1 & 4 to TDC and a 2' breaker bar on the flywheel puller, Draper version for minis. The flywheel bolts is out as I saw a video with a bloke trying to remove the flywheel with the bolt still in. I've wound the puller pretty tight and hit the end of the puller bolt with a hammer a couple of time to try and shock it but no signs of any movement at this stage
Do I just keep going winding it up or is there a knack/technique as I don't want to break anything
I've watched a couple of youtube videos with pre-verto clutches and I've got the Bill Sollis Ultimate Mini Builder DVD for some general info as I realise he is rebuilding a 1275 engine which is different and they all seem to do the "Blue Peter" get some of the way through then "here's one I made earlier"
Attached File  flywheel.jpg   108.2K   3 downloads
Darren
Edited by JDImini, 11 May 2019 - 11:13 AM.
#2 DeadSquare
DeadSquare
  • 3,382 posts
Posted 11 May 2019 - 11:57 AM
Give it another tighten, and look after lunch.
Before pullers were freely available, we used to remove the starter and using a long steel drift , hit the flywheel  with a sledge hammer.
#3 imack
imack
  • 2,380 posts
Posted 11 May 2019 - 12:35 PM
Make sure that puller bolt thread is well lubed
#4 ukcooper
ukcooper
  • 1,625 posts
Posted 11 May 2019 - 12:54 PM
taken the washer off?????????????????????????????????????
#5 DeadSquare
DeadSquare
  • 3,382 posts
Posted 11 May 2019 - 01:24 PM
There is no sign of a washer in the photo.!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!.
#6 JDImini
JDImini
  • 683 posts
Posted 11 May 2019 - 02:44 PM
is this the washer being referred to?
Attached File  Flywheel bolt and washers.jpg   106.32K   1 downloads
if so it was removed before I started.
by the way I didn't chew the washer it was like that when I took it off, honest.
#7 JDImini
JDImini
  • 683 posts
Posted 11 May 2019 - 02:46 PM
Thanks imack, it isn't so I'll wind it off lube it up and try again
#8 unburntfuelinthemorning
  • 2,003 posts
Posted 11 May 2019 - 02:51 PM
You need a decent heavy hammer to hit it with.  I find a lump hammer works well.
Strike the puller bolt hard and square on a few times, tighten a little and strike it again, tighten it slightly, make a cup of tea, have a fag (optional), strike it again, swear at it, give up, sleep on it, repeat the next day...
#9 JDImini
JDImini
  • 683 posts
Posted 11 May 2019 - 02:53 PM
Just looked and the flywheel's still firmly attached.
That sounds a bit brutal, but actually I might use the wooden handle of a hammer to give it a bit of extra persuasion
#10 DeadSquare
DeadSquare
  • 3,382 posts
Posted 11 May 2019 - 02:55 PM
No,no, no;  don't swear at it, Bless it.
#11 JDImini
JDImini
  • 683 posts
Posted 11 May 2019 - 02:58 PM
lol
Ok so it's not easy then
I'll get some spinach in me and keep going
#12 DeadSquare
DeadSquare
  • 3,382 posts
Posted 11 May 2019 - 03:03 PM
Darren
Before you go any further, MARK THE BACK PLATE & THE HOLE THROUGH WHICH YOU CAN SEE IT.   better still, put the clutch bolts and straps back on the flywheel and back plate.
The whole lot comes off together and was balanced as a whole.
Edited by DeadSquare, 11 May 2019 - 03:05 PM.
#13 unburntfuelinthemorning
  • 2,003 posts
Posted 11 May 2019 - 03:58 PM
lol
Some come off quickly, some take longer but most come off in the end.
#14 Steve220
Steve220
  • 5,142 posts
  • Local Club: BMC
Posted 11 May 2019 - 04:29 PM
Id just keep turning it until either it comes off or the puller breaks ?
#15 TheFabMini
TheFabMini
  • 459 posts
Posted 11 May 2019 - 04:37 PM
not to sound smug... but mine was only finger tight and fell off when i undid the big nut!
i have no practical experience but as much tension as you can get from the puller without it breaking, take the starter motor off and give the flywheel a tap through the starter motor hole, you should be able to turn the flywheel so you can tap around through that hole.
once again ive never personally tried it but i used to sell it in my old job.. you can buy a freezing penetrating spray (im sure eurocarparts/halfords will do something) its a similar concept to heating up the bolt but you freeze it instead. the sudden change in temperature+penetrating oil cracks and releases things.. i used to sell lots of the wurth version and never had customers complain so im assuming it worked
