My GTM Rossa kit car is fitted with a MG Metro Mk1 engine and manual gearbox and for a number of reasons, I am considering a change to an automatic box; therefore, am I able to bolt up an automatic assembly to my existing block or is there a specific block to match the automatic set up?
Thanks for any advice in advance
J
Automatic Gearbox Conversion Question
jaybeeonline
, May 12 2019 08:21 AM
5 replies to this topic
Posted 12 May 2019 - 08:21 AM
Posted 12 May 2019 - 09:23 AM
For what you are wanting to do, you'll need an Auto Engine and Gearbox.
The blocks, while for the most part, are similar, they are machined quite differently.
If the GTM uses a Mini Subframe, you'll also need an Auto Subframe as there are wider between the engine mounts.
Posted 12 May 2019 - 09:31 AM
Thanks. I knew in needed the subframe but was unsure about the rest of it
Thanks again
J
Thanks again
J
Posted 12 May 2019 - 11:34 AM
How’s the metro engine? want to sell it lol
Posted 13 May 2019 - 05:54 AM
Only if I had an automatic 1275 set up with a similar spec to mine!
http://www.theminifo...with-a-miniish/
J.
Posted 13 May 2019 - 07:11 AM
To be fair of you were wanting to go down the auto route you can pick up send hand engines very cheaply compared to manuals
