Sportspack Wheels ?
18 replies to this topic
#1 leepol83
leepol83
  • 1,744 posts
Posted 12 May 2019 - 01:42 PM
Hi I’m currently rebuilding a cooper sportspack and want to keep it looking originals be it little lower and Fatter, my question is can the wheels be made wider say 13” by 8 or even 7 as apposed to the 6” width? Obviously they’ll need cutting and welding is this doable ?????
Thank you ?
#2 Twincam
Twincam
  • 1,742 posts
  • Local Club: SMAG
Posted 13 May 2019 - 04:59 AM
I've personally never seen 'banding' done to alloys, only steel wheels. I have seen alloys being made into 'split rims' so there is always the possibility (and expense) if you wanted to go down that route.
Thats my experience, others may say different.
#3 Itsaminithing
Itsaminithing
  • 856 posts
  • Local Club: Not One Worth Mentioning
Posted 14 May 2019 - 10:44 PM
Band an alloy wheel? -probably not an economic option.
It's easy enough to buy 13x7 inch Sports Pack lookalike alloys but try driving a MPI with them fitted before going to the expense of buying a set for yourself.
Maybe you will like constantly changing knackered wheel bearings, the heavier steering, & the increased level of tram-lining (& that's on a car with fully adjustable suspension, let alone a standard set-up).
#4 g0myw
g0myw
  • Just Joined
  • 108 posts
Posted 15 May 2019 - 09:28 AM
got agree with itsaminithing those sportspack wheels look great ... but I prefer the driving experiance of a more traditional width wheel/tyre
#5 leepol83
leepol83
  • 1,744 posts
Posted 15 May 2019 - 05:57 PM
Ok thanks for you’re thought reallly appreciate it can anyone point me in the direction of these 7/13 sportspack alloys please
#6 danie garry
danie garry
    I love BMW minis
  • 2,296 posts
Posted 16 May 2019 - 07:12 AM
i don't think there was ever a 7inch wide sportspack wheel, the only options would be superlight/minilight style wheel that'll have some dish
i'm guessing you want the wheels "banded" inwards, ie. no dish though? i'd imagine that would cause some clearance issues for the tie rods anyway
#7 Steve220
Steve220
  • 5,146 posts
  • Local Club: BMC
Posted 16 May 2019 - 09:22 AM
There aren't any. Only ultralight or superlight 8 spokes.
#8 nicklouse
  • 19,067 posts
Posted 16 May 2019 - 10:56 AM
Thank you
you can get some wheels turned into 2 piece wheels where the outer rim is removed and a set of bolts is added to allow a new outer rim part to be added. often done on the old Mini special rims.
#9 Cooperman
  • 23,569 posts
Posted 21 May 2019 - 12:41 PM
The problem is maximum tyre width.
The widest road-legal tyre available in 13" is a 175/50 and for a 12" wheel it's 165/60. Max wheel width for either is 6" and any wider and the tyre will be stretched too much.
It is different for racing when sticky slick tyres are needed for dry track conditions.
Remember, the Mini was designed to have 145 width tyres on 3.5" wheels and even the original Cooper S had that as standard.
#10 leepol83
leepol83
  • 1,744 posts
Posted 22 May 2019 - 06:17 AM
Thanks everyone looks like it’s a bad idea, I’ll maybe fit some wheel spacers instead, what’s the safest way of doing this will I need longer studs ?
Thanks again
#11 Cooperman
  • 23,569 posts
Posted 22 May 2019 - 05:02 PM
Thanks again
There is no safe way to fit spacers and spacers screw up the steering geometry if used just to push the outer rims of the wheels further out. Not a good idea.
#12 leepol83
leepol83
  • 1,744 posts
Posted 22 May 2019 - 07:05 PM
Copy that!!! ??
#13 hutch8282
hutch8282
  • 25 posts
Posted 23 May 2019 - 02:32 AM
Go with your own thoughts, that's what these little cars are all about.
For me the wider the better, guys at force racing make some class split rims 13 x 8s with some 225 45 13 R888R and your able to get some serious power to the road.
#14 Bobbins
Bobbins
  • 1,526 posts
Posted 23 May 2019 - 06:07 AM
That makes a good car for looking at, much less so to actually drive. But everyone to their own.
#15 Cooperman
  • 23,569 posts
Posted 23 May 2019 - 09:25 PM
That width is entirely unsuitable for a small car weighing around 700 kg.
The ability to clear water on a wet road would be very poor. A 225 section tyre is best suited to a car weighing over 2000 kg.
Sounds like a triumph of styling perception over engineering sense.
