Help Needed
1 reply to this topic
#1 Ian1978
Ian1978
    Starting My Mini Up
  • 1 posts
Posted 12 May 2019 - 08:27 PM
Hi my 1990 classic mini is having some problems it starts up first time when engine is cold and stays running but as soon as engine is hot and I turn engine off it won't restart until engine is cold again, any help would be appreciated
#2 unburntfuelinthemorning
  • 2,003 posts
Posted 12 May 2019 - 09:21 PM
Do you have points ignition?  I had the same problem on my first Mini.  It was a points adjustment problem I had - once the gap was set correctly it started perfectly when hot.  I may have put new points and a condenser in there too but it was a long time ago.  Of course this may not be the problem on yours at all.
