Better Braking
3 replies to this topic
#1 projectjordan
projectjordan
  • 88 posts
  • Local Club: southwalesminis
Posted 13 May 2019 - 08:58 AM
Hi all
I have increased the sizes of the front calipers on my Corsa B, from 48mm to 57mm, and i'm also looking to change the rear drums for discs from the Corsa C (bias adjustment required).
All well known modifications on the Corsa. Also well known is the 'feel' of the pedal, It has been advised to change the master cylinder for a Cavalier MK3, however, getting hold of one is proving difficult, and mods to the cylinder itself are required.
Anyone know of a reverse look up for Master cylinders or servos that I could use to improve the system, without too much modification?
cheers
Ryan
Edited by projectjordan, 13 May 2019 - 09:08 AM.
#2 nicklouse
  • 19,067 posts
Posted 13 May 2019 - 09:20 AM
what are the new calipers off?
got any Part numbers?
#3 nicklouse
  • 19,067 posts
Posted 13 May 2019 - 09:37 AM
I am looking at a few variations bore size 22.2mm and 23,8mm and different size fittings M12 or M10 so knowing what you have fitted now is a must.
#4 projectjordan
projectjordan
  • 88 posts
Posted 13 May 2019 - 09:41 AM
Front calipers are of the Vectra B (2.0D, SRi etc), Remy DC82456/DC82457
Current Master cyl bore size is 20.64. with M12 outs. (LPR 1559)
Edited by projectjordan, 13 May 2019 - 09:42 AM.
