Whats The Name Of This Sensor.
5 replies to this topic
#1 JCmini
JCmini
  • 146 posts
Posted 13 May 2019 - 08:22 PM
1986 Mini automatic 998cc
Just discovered an oil leak coming from this sensor in the front just above the starter motor. Any one know what its called or what does it do?
thanks
Edited by JCmini, 13 May 2019 - 08:22 PM.
#2 mini13
mini13
  • 3,811 posts
Posted 13 May 2019 - 08:24 PM
oil pressure switch, it controls the orange oil light on the dash
#3 cal844
cal844
  • 9,735 posts
  • Local Club: TFMOC
Posted 13 May 2019 - 09:58 PM
Best to upgrade to either a 22psi light or a guage.
#4 JCmini
JCmini
  • 146 posts
Posted 14 May 2019 - 06:57 AM
Cool thanks for response.
Whats the advantage of a 22psi light or gauge?
I was just planning to do a straight swap for an oem one. Seen a few on ebay for around £5.
#5 Spider
  • 15,873 posts
Posted 14 May 2019 - 07:27 AM
Something else to fret over.
Just fit a standard Switch in, that'll be fine ;D
#6 Ethel
  • 26,814 posts
Posted 14 May 2019 - 11:00 PM
The standard switch operates at such low pressure that if it comes on it tells you your engine has just been knackered. Hopefully 22psi is enough to keep your bearings from disintegrating. A (mechanical) gauge is more like cardiograph, showing pressure fluctuations as they happen so you can deduce the cause.
