I've done another clean through and it's got a new rad cap and I'm still getting the same > temperature guage stays on the 'dot' if I keep it below 65mph. Any extended time above that the temperature starts to climb.
I've not let it hit the top of the temp guage, backing off the speed and allowing coolant to go round the heater matrix brings it down.
What I've noticed is that...
- it is spitting water out from under the new rad cap
- the expansion tank is also completely full of coolant (and overflowing so water is leaking out of that)
- took the rad cap off for a while (once cool) it looks like I've got a continuous weep of water out of the system, a pool of water forms on the floor. The hoses all look fine but maybe the water pump isn't sealing? (new water pump and gasket fitted during the rebuild).
I'm guessing as the cooling system is supposed to be a pressured system to work properly that any compromise to this will cause it to not behave and could be the root of my over heat? Or are the above things more likely because something else isn't right?
Should the expansion tank leak? if not I assume it's a bin-it job? It's leaking out of the stopper on the top and through one of the fixings that hold the bracket to the bottle. I know some say that they're not needed anyway?
