just a sanity check before it's too late .. do the tags (anti slip ?) on the mains and big ends go next to each other on the caps or on opposite sides? thanks
Bearing Orientation
Posted 16 May 2019 - 08:17 AM
Posted 16 May 2019 - 08:30 AM
they can only go the way that they fit.
and the caps are not mixable.
not really getting your question.
Posted 16 May 2019 - 08:46 AM
Usually next to each other or on the same side.
Posted 16 May 2019 - 09:11 AM
not worded very well. Once they are in the cap the cap can fit either way (on the correct rod) so that the tags are the same side as each other, or opposing sides
Posted 16 May 2019 - 09:13 AM
good, thought so. As a matter of interest what would be the outcome of getting this wrong?
N.B. not asking 'for a friend' I haven't bolted anything down yet !
Edited by johnv, 16 May 2019 - 09:13 AM.
Posted 16 May 2019 - 09:33 AM
The bore through all these caps is done with the caps and rods or caps and block bolted together and therefore are unique to each other. If they get mixed or fitted wrong way around, usually the crank will lock solid. Bearing Clearances are only of the order of 0.001 to 0.0027". The bores through the rods / block, are not necessarily centred between the bolts / dowels.
Posted 16 May 2019 - 12:37 PM
Explained exceptionally well by Moke Spider as always - you the man
Posted 16 May 2019 - 03:11 PM
all torqued up now and the crank turning nicely with the pistons installed so all good, thanks!
Posted 16 May 2019 - 07:55 PM
Oh get off the grass you !
Next you'll be the one saying 'Oh, what a nice underside'
Thanks for the kind words, I don't necessarily agree, but cheers,,,
