i got to the point where cheap hydraulic brake light switches kept letting me down, i found a different option. Using Goodridge banjo hoses there is an option to use a motorbike brake light switch. Go for the 3/8 short unf option on a single line system into the master cylinder or servo.
https://www.demon-tw...-switch-243429/
Works a treat
* will need additional wiring to interface with standard harness
Edited by The Principal, 16 May 2019 - 05:35 PM.
